Activity Forums Video Copilot Trouble getting rid of black solid background
  • Trouble getting rid of black solid background
    Posted by Kay Winnstean on March 9, 2010 at 2:38 am
    I created a ring using a Video Copilot tutorial called “The Ring,” and it looks exactly as it’s supposed to, with a four color gradient background. The problem is, I just want to use the actual ring part, and get rid of the background. But when I make the background layer invisible, all it does it revert back to a black solid. I can’t figure out how to get rid of this black solid. Any ideas? Thank you!!!!
    Ron Spencer replied 16 years, 6 months ago 3 Members · 3 Replies
  • Patrick Adkins
    March 10, 2010 at 6:47 pm
    I think the “black solid” you are referring to is the default color of the transparent background. You can check this by clicking the “Show Transparency” button. It is a button under the viewer that looks like a checkerboard. When you click that button it should change the black color to the transparent checkerboard. The black color can also be changed to other colors and just serves as a way to better see what you are doing.
    To export the ring with transparency put it in your render queue and choose “RGB + Alpha” in the settings. Once it has been exported with its alpha, you should be able to lay the ring over footage in your NLE.
  • Kay Winnstean
    March 11, 2010 at 4:14 am
    Wonderful, thank you!!!
  • Ron Spencer
    March 13, 2010 at 4:01 pm
    …and remember, when outputting you will need to choose a codec that supports an alpha channel i.e. the QuickTime Animation codec. Many output options will indeed render the background that you have selected as a BG color, typically black.
