Activity Forums Apple Final Cut Pro Legacy Trouble exporting XML
  • Trouble exporting XML
    Posted by Burt Holland on May 3, 2008 at 12:51 pm
    I am trying to export a Project via XML so I can open a FCP 6.02 project in 5.14. When I try to import the XML I created, I get an error message “Errors Found Importing saab burt 3 xml.xml (name of project)
    (file): Unable to create (file) as no (name) or (pathurl) is found.( line 1493 )”
    Even when I try to import the XML on the machine that created it I am exporting on, I get the same message. So the problem is in the export, not the import. I have the browser selected and nothing highlighted when exporting. Any ideas? I am using Apple XML interchange format 3.
    Burt Holland replied 18 years, 4 months ago 2 Members · 2 Replies
  • Walter Biscardi
    May 3, 2008 at 12:55 pm
    [Burt Holland] “I am using Apple XML interchange format 3.”
    Use 1 or 2. Anything beyond that, FCP 5 versions can’t open.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Burt Holland
    May 3, 2008 at 5:14 pm
    Thanks Walter, but I forgot to mention that I had tried 1 and 2 as well. Same problem. This is not the error that occurs when you use the wrong exchange format. And I’m getting the same problem when trying to reimport in to 6, so that’s not the issue.
