Activity Forums Apple Final Cut Pro Legacy Trouble exporting still images from Final Cut Pro 7
  • Trouble exporting still images from Final Cut Pro 7
    Posted by Meghan Rist on March 24, 2010 at 7:43 pm
    I have a still image (that’s a jpeg) that can be seen in the sequence in final cut but when I export it the image doesn’t show up. I have other images (that are tiff files)in the sequence that do show up. What could be the problem?
    Thanks for any help.
    Todd Gillespie replied 16 years, 5 months ago 2 Members · 1 Reply
  • Todd Gillespie
    March 25, 2010 at 4:15 pm
    Hi Meghan,
    While I’m not sure why this happens (i’ve experience it myself on a couple of occasions, but haven’t taken the time to track down the answer), if you can save the image as another format, it should clear up the problem. I had a tiff that wouldn’t show up, so I change it to .pict and it worked fine.
    Pict format is my fall back for just about anything, works well with Mac’s.
    I’ve also had success even doing a ‘save as’ with the original still image and it fixed the problem.
    Good Luck,
    Todd at UCSB
    Television Production
