trouble exporting mp3 audio
i have an animation that is synced to an mp3 file. when i export/render the file with the audio the first 8ish seconds skip a bit (a bad technoish loop), but after the skipping it is fine. when i export the file without sound, just the animation, and then place it into premiere and attempt to align the video with the same audio clip, the video is not the same length as it is in AE; im having to clip out the first 5-6 sec of the animation to match it with the audio. i have checked the fps and such with no luck. any insight would be appreciated.
thanks
abram
