Activity › Forums › Apple Final Cut Pro Legacy › Trouble exporting from FCP to XDCAM PDWU-1 SD
  • Trouble exporting from FCP to XDCAM PDWU-1 SD
    Posted by Daniel Ladeira on December 26, 2011 at 8:30 pm
    Hi there,
    two things, I have to export to XDCAM disk using the PDWU-1 deck, two medias, one in HD and the other in SD
    the one in HD i use HD422 50mbps audio 8CH, 24bits. No problem with thatm working nice.
    But… the disk in SD, which i have to use IMX40, 40mbps, audio 4CH,24bits, i just can’t do it because of the audio. i only get 8CH 16bits. Tried everything i know with no sucesss. Any clue?
    The timeline is set to 24bit depth, the audio output is set to 4 outputs, 2 channels each, dual mono (if i set it up to 2 outputs, 2 channels it wont work)
    I do the same i did for HD disk, but the HD disk i get the correct 8CH, 24 bit, and the SD i only get a 8CH 16bit.
    wonder if anyone can give me a tip
    thanks for ur attention
    Daniel
    Daniel Ladeira replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
