Activity › Forums › Apple Final Cut Pro Legacy › Trouble Exporting Fast Shutter Speed
  • Trouble Exporting Fast Shutter Speed
    Posted by Eric Bridenstines on August 17, 2010 at 1:47 pm
    Hello all,
    Trying to export some HDV footage of a baseball swing from a few different angles.
    Was shot on HDV, 29.97 fps, with a shutter speed of 1/2000.
    Looks great in FCP, but when I have exported it a few different ways, high quality mp4, high quality H.264, and a few others, I am getting some frame blending that does not look like the original footage.
    I ultimately have to get the footage into an avi format, but I figure if I can export a “clean” video first (able to stop frame by frame for an analysis without frame blending or motion blur) I can then just convert that file to avi.
    Eric
    Eric Bridenstines replied 16 years, 1 month ago 2 Members · 3 Replies
  • John Fishback
    August 17, 2010 at 3:08 pm
    What edit codec did you use? Exactly, how did you export?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Eric Bridenstines
    August 17, 2010 at 3:28 pm
    I believe I found a work around. The client wants the video in avi format, so I dropped the footage into an NTSC 720 x 480 sequence instead of the 1080 60i and exported that avi.
    Seems to work fine. I can see frame by frame without any blurring or frame blending.
    But, if I did want to export it from the 1080 60i without any blurring or frame blending, do you have any suggestions?
    I tried mp4 with an H.264 video format, 2000 kbits/sec, image size current and frame rate 29.97. Also did it at 59.94 fps and there was a lot of pixelization (is that a word).
    Also tried H.264 with best settings and and current frame rate and size….
    Thoughts?
    Thanks for the reply
  • Eric Bridenstines
    August 17, 2010 at 4:07 pm
    Will give that a try
