Activity Forums Adobe After Effects trouble dragging still images from project window to composition
  • trouble dragging still images from project window to composition
    Posted by Patrickbrooks on February 23, 2006 at 6:41 pm
    Im new to AE, so this question may and hopefully is basic, though i couldn’t find an answer in the book or on the forum yet. Here it is:
    When I drag a sized and prepped still image from my Project Window into my Compostion, or into the Timeline, the image in the compostion window has a transform box around it and is non-proportional to what it looks like in Photoshop. I have an image that is 7000 x 3950, though looks like 7000 x 6000 in the compostion window. Whats that all about?
    If I view the image in its own layer, it will show me a correctly dimmesional image. So why when i want to pan or zoom it in the compostion window and timeline is it giving me a misrepresented image non proportional to what it looks like in photoshop or in its own layer in AE?
    Any advice helpful,
    Thans,
    pb
    Patrickbrooks replied 20 years, 7 months ago 2 Members · 4 Replies
  • Patrickbrooks
    February 23, 2006 at 6:48 pm
    nevermind. I solved this simple little issue by dragging over image and clicking opt. and going to transform and then to scale with aspect ratio check at 100% by 100% of source.
    If theres a way around this step so i don’t have to do that everytime, let me know.
    thanks
    pb
  • Don Sciore
    February 23, 2006 at 7:01 pm
    Sounds like you might be using a 0.9 pixel aspect ratio comp and your Photoshop image is created in square pixels. Change you Comp settings PAR to Square pixels.
    Good Luck
    Don
  • Patrickbrooks
    February 23, 2006 at 7:47 pm
    thanks for the tip, though:
    what is PAR.
    Where do i change this to square pixels.
  • Patrickbrooks
    February 23, 2006 at 8:32 pm
    ok, got found it, thanks for the tip. i was actually using a pixel aspect ration of 1.5 for dvcpro1080
    i changed the aspect ration to square pixels.
    thanks again,
    pb
