Activity Forums Adobe Premiere Pro Trouble down-scaling 4K to 1080
  • Trouble down-scaling 4K to 1080
    Posted by Luke Halyk on November 24, 2014 at 2:56 am
    I have done some editing in premiere before but am new to working with 4K footage. I am definitely no professional. I typically select a my custom preset (1080, 24fps, progressive) and drag a 4K clip into the timeline. It asks if I want to change my sequence settings or keep them the same, and I have tried both:
    1 – When I change the settings, the sequence becomes the dimensions of my 4K clip, and previewing is a breeze; no frames dropped. However, this will not do because my I want to export and have my timeline in 1080.
    2 – When I stay with my original settings, the 4K clip blows up, as it should being a much larger file in a 1920×1080 frame. However, when I scale the clip down to the correct amount, it fits fine but I can hardly play more than 2 or 3 frames in real time.
    This video also confused me because it seems like this person didn’t have the problem at all, and was able to change his sequence settings on the go.
    https://www.youtube.com/watch?v=9oEWvBsN63U
    Can someone please explain this to me and show me a shortcut that would make handling this footage easier? Thanks!
    Paul Neumann replied 11 years, 10 months ago 4 Members · 3 Replies
  • Daniel Sametz
    November 24, 2014 at 5:00 am
    He said that his Computer was really buffed, hyperclocked and Stuff.
  • Matthew Mann
    November 24, 2014 at 5:39 am
    Always edit with the native settings with the clip for best performance and render to 1080p in your export settings.
  • Paul Neumann
    November 24, 2014 at 4:38 pm
    Use a 4k sequence and change the resolution on your Program Monitor. Should be fine.
