Activity Forums Apple Final Cut Pro Legacy Trouble digitizing Clips –
  • Trouble digitizing Clips –
    Posted by Dennis Dean on August 24, 2009 at 8:45 pm
    Just starting to digitize using the Log and Capture method and everything seems to be fine EXCEPT once I’ve logged some clips the Batch Capture command gives me an error code saying it can’t find the Time Code. Time Code is, however, coming into the system… but I’ve noticed it’s only appearing under the Media Start and Media End columns for each clip. The In and Out columns show as Not Set. I suspect i’ve overlooked something but not sure what. ANY HELP would be appreciated –
    Any help appreciated. I’m feeding HDV/DV out of a Sony HVR-Z7U thru the Firewire 400 port into a G5 Dual running 10.4.1
    Thanks very much!
    Dennis Dean
    The Dean Group
    -It’s about results-
    http://www.deangroup.com
    Dennis Dean replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
