Activity Forums Panasonic Cameras Trouble copying and ingesting p2 cards
  • Trouble copying and ingesting p2 cards
    Posted by Francesca Soans on March 23, 2013 at 1:32 am
    Hi, I am caught between old and new technologies in the middle of a project and need help. I am trying to both ingest and copy the contents of p2 cards and keep running into problems recently although this workflow worked fine before.
    System: mac powerbook G4 with 10.4.11 (yes, that’s old)
    p2 F series and older cards
    Panasonic HVX200AP
    FCP 6.0.6
    Prob 1: When I use the Finder to copy the contents of the p2 including the Contents Folder and Lasttext, it does not work consistently. Gives me error-36.
    I read earlier posts about using PCMS software but that needs an Intel processor–I have a power pc. Is there something else available for a power pc? I also read Shane Ross’s suggestions but they don’t apply in my case.
    Prob 2: When I use Log and transfer to ingest either directly from the card or from the hard drive folder created above, the transfer does not go through.
    Prob 3: This seemed to happen with spanned clips for footage than ran over two cards, so I altered my shooting to stop shooting 5 minutes before the end of a card. I then removed the card before resuming shooting with the second card. despite this, some of the files are still marked spanned. How is that possible?
    I need to be able to back up my footage to reuse the cards and am in the middle of production. Does anyone have any solutions? Thanks
    Steve Eisen replied 13 years, 5 months ago 3 Members · 2 Replies
  • Marcus Van bavel
    March 24, 2013 at 3:10 am
    Regarding problem 2&3, you might look at Raylight for Mac to import the clips instead of using Log and Transfer. It works on a Power PC. It handles each MXF file separately so there is less chance of a problem with spanned clips (because it ignores spanning and you group-drag the spanned clips into your sequence instead). Also it does not re-wrap the clips but instead makes a small QT reference file, so it runs much faster than Log & Transfer.
    https://dvfilm.com/raylight/mac
    Raylight by DVFilm
    dvfilm.com/raylight
  • Steve Eisen
    March 25, 2013 at 12:02 am
    Spend the money and get ShotPut Pro. Finder copy is very unreliable especially on an old system like yours.
    Upgrade your computer and OS in order to use the latest software.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
