Activity Forums Audio Trouble connecting Mixpre-D with 7D
  • Trouble connecting Mixpre-D with 7D
    Posted by Stephen Lewis on August 18, 2013 at 2:08 am
    I already asked this on the SD forum but I thought I couldn’t hurt to try here too…
    I’m using a Hosa dual xlr female to single 3.5mm cable to connect the mixpre d to the 7D. (mixpre xlr outs are set to Mic level because 7D only accepts Mic level) When I send the tone to the 7d, I have to increase the rec level on the 7d quite a bit (see here: https://imgur.com/LVDbXoY) to get it to reach -12dbfs. Why is this? I’ve read that one should only have to set the dslr rec level “1 click” above “0” (meaning extreme left in the pic) for interfacing with a sound devices mixer. (because then the crappy dslr preamps aren’t being engaged)
    When I listen to the sound on the 7D, it has quite a bit of noise/static which I’m guessing is because of the camera’s preamps??
    Thanks for your help.
    View post on imgur.com
    Ty Ford replied 13 years ago 3 Members · 7 Replies
  • 7 Replies
  • Brian Reynolds
    August 18, 2013 at 6:39 am
    What’s the connections on the cable?
    Is it wired as a stereo cable or a dual xlr combine cable?
    Are the XLR connectors marked as L/R?
    What happens when one of the XLR connections is removed from the mixer, what shows in the meter of the D7?
  • Stephen Lewis
    August 18, 2013 at 6:48 am
    This is the cable: https://www.amazon.com/gp/product/B000068O5K/ref=oh_details_o06_s00_i00?ie=UTF8&psc=1
    I think it is a stereo cable (as it says in the amazon description), however the package says Dual XLR3.
    There are no L or R markings on the XLR connectors.
    I will do the experiment of trying only one connection tomorrow and get back to you.
  • Brian Reynolds
    August 18, 2013 at 8:19 am
    This is from the ‘MixPre D” manual…..
    “The two XLR outputs are active-balanced connections, each capable of driving long lines. These connections can be used as either balanced or unbalanced. When unbalancing, use pin-2 for (+) and pin-1 for ground; float (leave open) pin-3”
    Going unbalanced, as you are there might be a short between pins 1 and 3….
  • Ty Ford
    August 18, 2013 at 1:52 pm
    Hello Stephen and welcome to the Cow Audio Forum.
    Brian has given you some good information.
    But, as I have heard before…..
    “You can use the Magic Lantern Hack to disable AGC on the 7D. It’s not destructive, boots off your memory card when you boot the camera. It has a few other nice tricks up it’s sleeve also.
    The input is mic level, but you can buy a beachtek adapter to give you two XLR and a line input for it. They aren’t powered so no condensers and are going to starve any decent dynamic mic so I’d only use it to bring line in from a mixer or something. Unless you are needing serious fidelity, you’ll probably get roughly equal results running a mixer into the mic input at a very, very low level.”
    NOTE: I HAVE NOT TRIED THE ABOVE AND MAKE NO GUARANTEES ABOUT IT OR WHAT IT MIGHT DO THAT YOU DON’T WANT.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Stephen Lewis
    August 18, 2013 at 4:33 pm
    To be honest, I have no idea how to unbalanced an xlr cable or what the different pins are or how to manipulate them. I am just going to buy this Sound Devices cable: https://www.bhphotovideo.com/c/product/293005-REG/Sound_Devices_XL_3_XL3_Mini_Male_to.html
    That should solve my issues, correct?
  • Stephen Lewis
    August 18, 2013 at 6:28 pm
    quick follow up:
    Since it seems like Brian was right that I shorted pins 1 & 3 by connecting balanced to unbalanced… does that mean I’ve done permanent damage to any of my gear?
  • Ty Ford
    August 18, 2013 at 6:40 pm
    prolly not
    Ty
