Activity Forums Apple Final Cut Pro Legacy Trouble capturing P2 footage
  • Trouble capturing P2 footage
    Posted by James Wright on May 29, 2009 at 1:54 pm
    im using Final cut pro 5.0.4 on a G5 powermac. Ive got the capture destinations set to the Mac hard drive and a External hard drive. The Mac has 50GB of space and the external 60GB.
    For some reason when i try to capture a particular clip shot on a P2 i get the dreaded ‘capture scratch discs are full’.
    The P2 folder itself with all the various audio & video etc says it is 4.89 GB.
    So could anyone point me in the right direction of solving this.
    cheers
    Arthur Lunn replied 17 years, 3 months ago 5 Members · 5 Replies
  • Walter Biscardi
    May 29, 2009 at 2:24 pm
    You have to Log and Transfer the footage. There is no “Capturing” of P2 footage.
    I’m not even sure FCP 5.0.4 even supports the P2 workflow.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Steve Eisen
    May 29, 2009 at 2:27 pm
    First thing, you do not capture P2 footage, you import it using FCP v5.
    Second, never, never, store media on your system hard drive.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Steve Eisen
    May 29, 2009 at 2:30 pm
    P2 import started with v.5.04
    Steve Eisen
    Board of Directors
  • Shane Ross
    May 29, 2009 at 2:59 pm
    here is a tutorial on the FCP 5 P2 workflow:
    P2 workflow: P2 Workflow Tutorial
    make sure that your Capture Scratch is set to the proper drive.
    Shane
  • Arthur Lunn
    May 29, 2009 at 3:06 pm
    James,
    You will have import>p2 under your import options, if you have at least FCP 5.1.4
    Also be sure your capture scratch is set to the ext HD, NOT the desktop or Mac HD.
    I very strongly suggest that you get another hard drive for archiving p2 footage because you never know when you might have to go back to the raw footage to get something.
    Archiving is easy, just drag and drop contents from p2 card into it’s own folder (e.g, “card 1 beach shoots”). NEVER forget to include the .txt file!
    Also 60GB HD is too small for P2 cards archiving or storage.. you would only have room for a couple cards worth of footage. You should get at least a 250 or 500GB. Western Digital is ideal and the cost is reasonable.
