Activity Forums Apple Final Cut Pro Legacy Trouble Capturing HDV footage
  • Trouble Capturing HDV footage
    Posted by Noel Powell on September 21, 2007 at 11:17 pm
    I’ve been trying to figure this out for hours but to no avail. Please help!
    I’m using Final Cut Pro 5 with the latest version of OS X on a newer iMac. I shot some 1080i footage with my new Canon XHA1 and have it hooked up to the mac with a 4-pin to 6-pin Firewire 400 cable. I used the HDV-1080i60 Easy Setup option. When I open the Log and Capture window, I can control the camera functions from the computer but I can’t preview the footage in the window. Also, I can capture the footage (I have to use the viewfinder to preview it as it captures), but when I drag the clip to my timeline, it comes in un-rendered and has a different aspect ratio than my canvas (a little shorter). I can’t even watch the clip without doing a very time-consuming render. I’ve changed the canvas aspect ratio to every available shape in the Sequence Settings box, hoping it would solve the render problem, but there’s no match. Any ideas?
    13 replied 19 years ago 2 Members · 2 Replies
  • Noel Powell
    September 22, 2007 at 4:09 pm
    NVM. I started a new project and it worked this time! I have no idea what went wrong…
  • 13 Create COW Profile Image
    13
    September 23, 2007 at 6:22 am
    [nopow] “NVM. I started a new project and it worked this time! I have no idea what went wrong… “
    I will tell you what was wrong. If you change the easy set up, you MUST create a new project in order for it to have the properties of the easy set up. Doing the Easy set up douse not change the properties on a project currently open. That is why you were required to render.
