Activity Forums Blackmagic Design trouble capturing from ATEM into Premiere Pro
  • trouble capturing from ATEM into Premiere Pro
    Posted by Chris Powers on January 25, 2012 at 9:08 pm
    So – I have an ATEM TVS with two SOny NX5U’s running into it via SDI.
    From the switcher I’m taking an SDI program out into a Decklink SDI capture card, which I plan to capture in Premiere.
    SO – I set premiere to capture an uncompressed 8bit signal and it seems ok for 5-10 minutes. However, if I record for 40 minutes or so – when it comes time to stop the capture, I get a “no capture settings defined” error.
    So far, it seems like length of capture is the only thing causing this to happen.
    Also – the files are something like 4Gb a minute. I’m assuming thats normal since it is uncompressed video – is there a way to capture something a bit less massive and still use sdi?
    Thanks for entertaining these beginners questions.
    Chris Powers replied 14 years, 7 months ago 2 Members · 3 Replies
  • Bob Zelin
    January 25, 2012 at 11:58 pm
    Choose a different compression codec in Premier. Use DVCPro.
    Who uses uncompressed video ? Are you shooting a feature film ?
    Bob Zelin
  • Chris Powers
    January 27, 2012 at 3:13 pm
    Hey Bob, thanks for the reply. I know – the uncompressed video is WAY more than we need. However, when I switch to DVCPRO (under the settings tab for Blackmagic capture in the Premiere capture window)I instantly get the “no capture settings defined” error – even though I just set that capture setting……that’s what was confusing me…
  • Chris Powers
    January 31, 2012 at 2:27 pm
    Bob, do you have any idea why a short capture duration would work fine in Premiere whereas a longer one doesn’t and gives me the “no capture settings defined” error?
