Activity Forums Apple Final Cut Pro Legacy Trouble capturing DVCAM in FCP
  • Trouble capturing DVCAM in FCP
    Posted by John Mecklenborg on February 12, 2008 at 5:18 pm
    I am trying to online a sequence with DVCAM ftg, but I keep encountering dropped frames every time I try to capture a clip, and it might be because I’m trying to import at a higher resolution than possible. Should I be capturing the ftg at DV or DV50 to achieve the best quality?
    John Mecklenborg replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    February 12, 2008 at 5:43 pm
    YOu can only capture dv @ dv quality. You can’t transcode dv to dv50 on the fly via firewire/FCP. If you had a deck and a capture card you could capture at a higher quality codec than dv.
    Jeremy
  • John Mecklenborg
    February 12, 2008 at 10:29 pm
    Unfortunately, that’s what I figured. Thanks, Jeremy.
