Activity › Forums › Adobe After Effects › Trouble animating isometric in AE 2.5D
  • Trouble animating isometric in AE 2.5D
    Posted by Ben Cone on June 19, 2015 at 2:18 pm
    Hey guys,
    So I’m working on an isometric animation in After Effects, and I’m having trouble animating in 2.5D this isometric image. I made all my assets as 2D illustrator vectors, so true 3D animation isn’t really an option. My problem is that I want to rotate in 2.5D, but every time I do it gives me weird results. Any ideas?
    Here’s an image of what I’m trying to achieve https://imgur.com/WxIjzmr
    Also, I’ve tried rotating all 3 axes to achieve the effect, but that gives me weird rotations and unwanted movements.
    Any help or advice is appreciated.
    Thanks in advance!
    View post on imgur.com
    Kalleheikki Kannisto replied 11 years, 3 months ago 3 Members · 3 Replies
  • Daniel Waldron
    June 19, 2015 at 3:32 pm
    Is your Anchor Point located where you want the rotation to originate? If you are trying to “fold” the vertical layer down on top of the other layer, you will want to use the Pan Behind tool (Y) to move the anchor point to the bottom of the layer.
  • Kalleheikki Kannisto
    June 20, 2015 at 7:00 pm
    Hi Ben,
    You’re really just simulating a 3D move in 2D, not even 2.5D, so this is how you’ll have to do it:
    You can skip animating the slant, but it will not look as good, as the plane will move linearly, not in a circular fashion.
    June 22, 2015 at 6:59 am
    Or, you can make the “lid” asset a square and use corner pin and null objects to animate it.
