Activity Forums Adobe After Effects Trnsform effect
  • Trnsform effect
    Posted by Paulo Zilberman on April 15, 2021 at 8:39 pm
    Hello
    I have some layers to which I applied the transform efeect – skew.
    When I move the layers they slide outside the original position and I could not find any solution in the effects manual
    Paulo Zilberman replied 5 years, 5 months ago 2 Members · 2 Replies
  • Robert Müller
    April 16, 2021 at 9:16 am
    Hi Paulo, the only solution I found is to use the position inside the Transform effect. If you still want the option of Motion Paths you could link the position value of the transform effect to the position of a null via expressions
  • Paulo Zilberman
    April 16, 2021 at 6:27 pm
    Hi Robert, thank you very much, your solution worked fine.
    I just animated the position values of the effect.
    What baffles me is that the layers drift even if I do not move anything, just the camera.
