Activity Forums VEGAS Pro tripple split frame with moving mask problem
  • tripple split frame with moving mask problem
    Posted by Andreas Haun on June 30, 2008 at 11:49 am
    hello,
    i’m new here and say hello to all.
    i’ve vegas 8 pro and 3 clips with hard working man. now i want to split my frame in 3 masks. one mask left, one right and one in the middle of the frame. every mask shows one clip. so far so good i’ve got this working. the problem is to have the clip moving (left and right) within the mask (to have the working man always in the middle of the mask) without moving the mask over the frame.
    John Rofrano replied 18 years, 1 month ago 2 Members · 6 Replies
  • John Rofrano
    July 2, 2008 at 5:20 pm
    > The problem is to have the clip moving (left and right) within the mask (to have the working man always in the middle of the mask) without moving the mask over the frame.
    There is no way to avoid this. If the subject of the mask is moving, the mask must move along with it. You need to keyframe the masks movements to maintain the mask over the subject. Tools like Boris FX have motion tracking which will help you do this but with Vegas alone you need to create this motion manually yourself.
    If you created the mask using the Mask tool in Pan/Crop this shouldn’t be to hard to do. Turn Sync Cursor on in the Mask timeline. Then just move the mask as the subject moves and Vegas will create new keyframes.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Andreas Haun
    July 2, 2008 at 6:43 pm
    hi again,
    yes i know that i’ve have to move the mask by hand but the mask wanders all over the frame and not the clip in the mask. i need the mask to stay firm on one side of the frame and the clip is moving inside teh mask.
    cheers
  • John Rofrano
    July 4, 2008 at 1:37 pm
    If you want the mask to remain in the same place and move the video under it then you might want to make the mask a separate track. This will allow you to move the video any way you want while maintaining the mask in the same position.
    ~jr
  • Andreas Haun
    July 4, 2008 at 8:22 pm
    yes thats it – but how.
    is there a tutorial about this?
    cheers
    andreas
  • Andreas Haun
    July 4, 2008 at 9:26 pm
    i tink i managed it.
    first video layer mediagenerator”split screen” white/black (compositon mode=multiply)parent compiste mode=add
    composition child=movie for the left split screen
    second video layer “split screen” black/white (compositon mode=multiply)
    composition child=movie for the right split screen.
    or is there any better way???
  • John Rofrano
    July 4, 2008 at 10:28 pm
    Yes that’s it. I usually add a Generated Media Solid White to the upper track and cut the mask out of that, then change the composite mode to Multiple (Mask) and make the track under it a child. This sounds like what you did. This keeps the mask independent of the event it’s masking.
    ~jr
