Activity Forums Adobe After Effects Trimming Vid, then just save.. not re-encoding
  • Trimming Vid, then just save.. not re-encoding
    Posted by Kelly Johnson on November 29, 2008 at 5:05 am
    Am I mad or is this another genius thing that should happen… can I not simply edit a video clip and just “save as” without going through an encoding process?
    I have a big file, about 984 megs and I need to cut out about 5 minutes in the middle.
    Trouble is, I then have to re-render down to a new file which means setting a codec and all.
    I’m just trying to find some app that will act like Photoshop essentially;.. open a tif, crop a little and save. Done. No worrying about changing parameters (in this case encoding).
    Can this be done and I’m just overlooking it or is there some reason a video editing app cannot simply cut and save the file?
    Jeremy Allen replied 17 years, 9 months ago 3 Members · 2 Replies
  • Criis Daw
    November 29, 2008 at 12:15 pm
    i might be missing the point but cant quick time pro do that ?
  • Jeremy Allen
    November 29, 2008 at 6:15 pm
    Yep.
    With Quicktime Pro, you simply open the video, set the in (I) and out (O) points of the section to be deleted. Then you just cut and save.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
    DualCore G5 2.0 GHZ, 2GB RAM, OSX 10.4.11
    AE CS3
