Activity Forums Apple Motion Trimming an object in Motion 5
  • Trimming an object in Motion 5
    Posted by Phil Munckton on March 15, 2012 at 7:30 am
    I might have missed something here in 5 but in Motion 4, to trim the IN or OUT point of an object to the cursor position you would hit I or O
    Although the manual for 5 says the same works, pressing I or O moves the PROJECT START point to that location not trimming the object.
    Holding shift and pressing I take the cursor to the start point. Have they done away with the one key stroke Trim or is it hidden somewhere else, cause I cant find it
    Thanks Phil
    Mark Spencer replied 14 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Mark Spencer
    March 15, 2012 at 2:40 pm
    I and O work the same in Motion 5. Try trashing your prefs.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Phil Munckton
    March 16, 2012 at 3:25 am
    I tried That Mark No result
    Strangely enough in the drop down menu bar in motion 4 there is an I and O indicating keyboard short cut to Mark in and Mark out.
    Yet in Motion 5 Its not there.
    I have 5.0.2 is there a bug fix in a later version?
  • Mark Spencer
    March 16, 2012 at 3:57 am
    5.0.2 is the latest. Just trash the app and redownload from the App store.
    Mark Spencer
  • Phil Munckton
    March 20, 2012 at 6:10 am
    mark Just downloaded Motion again and the same thing still exists.
    Mark play range in is the ‘I” and mark play rang out is the “O”
    The is no I & O on mark in and out as it in in Motion 4. What version of Motion are you using to have it work the same as 4?
    Thanks Phil
  • Mark Spencer
    March 20, 2012 at 12:40 pm
    5.0.2
    Mark Spencer
  • Phil Munckton
    March 21, 2012 at 12:28 am
    I see your is working correct but a screen shot of mine is attached. could it be a keyboard setting or something
  • Phil Munckton
    March 21, 2012 at 12:51 am
    Found the problem
    Under Motion in the menu I selected commands and found it was set to Final cut Pro set changing it to standard set brought up the normal settings as it should be
  • Mark Spencer
    March 21, 2012 at 1:05 am
    I should have known – that same issue tripped me up in FCP X!!! Glad you figured it out.
    Mark Spencer
