Activity › Forums › VEGAS Pro › Trimmer Window
  • Trimmer Window
    Posted by Craig Stancher on July 29, 2008 at 9:22 pm
    I was playing around with the video media generator, and screwed something up (using Vegas 8.0). I tried to drag and drop something from a “pop-up window” that I was editing in, and now all my generated media shows up in the trimmer window (instead of in it’s own pop-up). How do I revert back to the old way…where I can edit something (text, etc.) in an extra window, rather than the small trimmer window?
    I’m not sure if this makes sense, but any help would be greatly appreciated. I’m quite annoyed by it.
    Craig Stancher replied 18 years, 2 months ago 2 Members · 2 Replies
  • Theo Van laar
    July 29, 2008 at 9:49 pm
    There are 2 possible solutions for your mess:
    1) open the default lay out via VIEW-WINDOWS LAYOUT- LOAD DEFAULT LAYOUT
    If that doesn’t work then
    2) Hold CTRL + SHIFT during start up of Vegas. Then you should begin with a fresh start…
    And text editing? I do it in the text editor…
    Theo
  • Craig Stancher
    July 29, 2008 at 10:35 pm
    Thank you, thank you, thank you! I had already tried loading the default layout, with no success. But the CTRL + SHIFT trick absolutely worked. I really appreciate the timely response…I was driving myself insane!
