Activity Forums VEGAS Pro Trimmer window behaviour
  • Trimmer window behaviour
    Posted by Phil Seymour on September 18, 2011 at 12:42 am
    When I scrub a clip in the trimmer window, I should be able to press “i” to select a new in point and “o” for an out point. But when I do that, nothing happens. I can select the little yellow triangle and scrub it up to the out point and so create a selection, but I can’t figure out why the i-o combination isn’t working.
    It isn’t something that bothers me overly, but I believe it should work. Anyone got an idea why it is – or isn’t – so?
    Vegas Pro 10d (not e ’cause am i the middle of a big long project and 11 is on its way).
    Phil Seymour replied 15 years ago 3 Members · 4 Replies
  • John Rofrano
    September 18, 2011 at 4:07 am
    [Phil Seymour] “I should be able to press “i” to select a new in point and “o” for an out point. But when I do that, nothing happens.”
    That works for me so it should work for you (although I’m using Vegas Pro 10.0e so maybe it didn’t work in 10.0d?) Did you remap I and O to something else. It should just work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Phil Seymour
    September 18, 2011 at 6:37 am
    Is gotta be something to do with me, John. I opened an old Vegas 7 that I had on another computer and it won’t do it either. And no, I haven’t remapped any keys. I’ll go to my favourite ruminating place and ponder – or ruminate – or both.
  • Edward Troxel
    September 19, 2011 at 1:11 pm
    I and O do not work if “Collapse Loop Region” is turned on in the preferences.
    Edward Troxel
    JETDV Scripts
  • Phil Seymour
    September 20, 2011 at 10:21 am
    And the kewpie doll goes to….
    Well, where did you find that one out? From writing scripts, I guess, but thanks for solving my problem!
