Trimmer – what is “save regions”?
Posted by Gilles Gagnon on June 13, 2012 at 4:21 pmIn the trimmer, if I create regions they seem to be saved because if I close my project and re-open it… there they are.
so… what does the “save regions and markers” feature do?
Cheers,
GillesGilles
Gilles Gagnon replied 14 years, 3 months ago 2 Members · 5 Replies -
Rob Mack
June 14, 2012 at 5:20 amThe button allows you to manually save the regions and markers. There’s a preference setting that turns off the automatic saving of trimmer marks. If you turn that function off then you’d need to use the button.
Rob Mack
Gilles Gagnon
June 14, 2012 at 11:55 amI see… thanks Rob. I must have the option turned on then. This makes sense. I’ll check.
Thanks for the info.
GillesGilles
Gilles Gagnon
June 14, 2012 at 2:41 pmHi Rob,
Strange, I checked my prefs and the checkbox for “save trimmer regions…” was NOT checked. Yet, when I open my project, the regions are there.Perhaps when the box is checked, they are actually saved in the clip (is this possible?) so when the media is inserted in another project, they come along?
Gilles
Gilles
Rob Mack
June 14, 2012 at 5:37 pmThe trimmer either saves the markers within the media file or in a sidecar .SFL file. You need to preserve those SFL files when you move or back up your media.
Yes, if you save markers and regions for a clip in the trimmer then they’ll come along to the next project.
Rob
