Activity Forums Adobe Encore DVD Trimmed Timeline Issue cont’d
  • Trimmed Timeline Issue cont’d
    Posted by Vegard Sorby on February 24, 2006 at 10:26 am
    I continue an older post, as I really need help.
    The facts:
    I create a timeline with an AVI file, and trim the beginning approx. 5 sec to after the blip of the “2” (of the countdown)
    I then create 7 chapters (with several minutes in between, it’s an 18 min film)
    I then build (transcode) and burn the DVD, and it works perfectly when played back. Straight after the first DVD is burned, though, the timeline has changed, with all the chapters moved over approx 15 frames (and therefore, as Jeff Bellune said in an earlier post, it migth be a GOP issue).
    But why does it work first time, for then to suddenly change? It is a HUGE problem, as I have to redo the timeline every time, which breaks the link to my chapter selection menu, and everything has to be re-transcoded.
    Quick responses much appreciated.
    Vegard
    Encore 1.5 (yes, I should get v.2)
    Jeff Bellune replied 20 years, 6 months ago 3 Members · 4 Replies
  • Jeff Bellune
    February 24, 2006 at 2:00 pm
    Vegard,
    I didn’t realize that *all* of the chapters had moved. Encore 1.x has a slight problem with previewing chapters that are imported from Premiere Pro in the Monitor window – they sometimes show up in the wrong place (by about 15 frames). The good news is that even though they preview incorrectly, they get placed correctly when the disc is burned.
    Even if you didn’t import your chapter markers from Premiere Pro, this still may be a preview-only issue. Try this: once your chapter points show up 15 frames off, burn another disc right away and see if the new burned disc has the chapter markers in the right place.
    HTH,
    Jeff
  • Matthew Press
    February 24, 2006 at 2:33 pm
    Why don’t you Trim a little further past the Blip then you have been.
    I’ve had really good luck with the Timeline trim feature. It’s not frame accurate but you can get a good feel for where it will start after a few tries.
  • Vegard Sorby
    February 24, 2006 at 4:45 pm
    Thanks a lot Jeff for your help, it was just like you said!
    I’m so relieved, was imagining having to redo the timeline and transcoding for every copy I made…
    A very frustrating, but luckily deceiving, bug..
    Cheers!
    Vegard
  • Jeff Bellune
    February 24, 2006 at 7:40 pm
    [Vegard] “A very frustrating, but luckily deceiving, bug..”
    …which has been fixed in 2.0. 😉
    Glad I could help.
    -Jeff
