Activity Forums Adobe Premiere Pro trimmed project won’t open
  • trimmed project won’t open
    Posted by George on August 22, 2005 at 6:02 pm
    I am using Premiere Pro 1.5 on a 3Ghz, 1 GB ram system. I had trimmed a project for archival purposes, and saved all the necessary files. I have even saved the CFAs and Preview files. I went to open the trimmed project (which I’ve done several times successfully with other projects) and the project will not open. It begins loading, as I would expect, but it does not finish the loading process. It hangs with one or two progress bars left. Note: this is BEFORE the windows open that ask you to relink your media.
    Has anyone seen this? I sure hope there’s a fix out there, or something I’m not thinking of.
    Thanks in advance.
    George
    John Baum replied 21 years, 1 month ago 2 Members · 1 Reply
  • John Baum
    August 22, 2005 at 6:21 pm
    Maybe one or more pieces of media got corrupted? You could try renaming or moving files so the project cant find them and relink manually to try and find the problem file.
