Activity Forums Adobe Premiere Pro trimmed Project cs3
  • trimmed Project cs3
    Posted by Arthur489 on November 30, 2007 at 4:21 pm
    Hi ,I’ tryng to trim my project with the Proj.Mmgr.
    Create a new trimmed project,exlude unused Clips, include handle frame 6, are my settings.
    Now my problem is that when I open the trimmed project, it seem that the in and out point of ,y clips are not like the original(and I miss some file that I ve on another drive)…
    Do you guys have an idea where can be the problem?
    Arthur
    Arthur489 replied 18 years, 9 months ago 2 Members · 2 Replies
  • Jon Barrie
    December 1, 2007 at 5:45 am
    Try copying to new location instead of New Trimmed. See if the problems are solved. Then do the New Trimmed.
    Make sure the project you are working with and the footage are all the same format NTSC or PAL. If there are conflicting you’ll get all sorts of errors in timecode IN OUT points as the frame rate is different.
    – Jon 🙂
  • Arthur489
    December 1, 2007 at 3:07 pm
    thanks Jhon, yes my footage is all NTSC.I will try your tip and let you know
    Arthur
