Activity Forums Apple Final Cut Pro Legacy trim to playhead?
  • trim to playhead?
    Posted by Adam Welch on July 31, 2006 at 9:40 pm
    I used a feature once in Apple Motion via keyboard shortcut to trim my selection to the current playhead position. Is there a likewise feature in FCP 5.1?
    Thanks so much,
    Adam
    P.S.
    I can’t remember the keyboard shortcut inside of motion anymore either….any help?
    Tom Meegan replied 20 years, 1 month ago 2 Members · 1 Reply
  • Tom Meegan
    August 1, 2006 at 2:42 am
    X – marks the current clip
    I – marks an in
    Delete -Lifts the clip without effecting anything down stream
    Shift-Delete removes the back end of the clip, and slides everything down stream to the point of the playhead.
    Note: Be aware of auto-selects when using this technique with multiple layers.
    Alternatively, use O to mark an out and Delete will remove the front end of a clip.
    Have been wishing for the abiltity to script those four keystrokes into a Macro. I use them a lot when roughing an edit in.
    In Motion, select the clip in the time line and hit O.
    Tom
