Activity Forums Adobe After Effects Expressions Trim paths trigger’s on inPoint of layer
  • Trim paths trigger’s on inPoint of layer
    Posted by Mac Lad on March 12, 2018 at 11:02 am
    Hi Guys,
    Need some Expression help to trigger Trim paths animation depending on inPoint of the layer. I have multiple layers which have trim paths applied to it which are controlled by the main layer which has the slider controls to it. I have stacked these layers randomly. I am trying to add an expression which can start the trim paths animation depending upon the inPoint of the layer. Is it possible..?
    Mac Lad replied 8 years, 2 months ago 2 Members · 2 Replies
  • Matthias Weiner
    March 12, 2018 at 1:21 pm
    This may help you?
    //get relative time
    t = time-inPoint;
    //get comp fps
    fps = 1.0 / thisComp.frameDuration;
    //set some user var
    start_val = 0;
    end_val = 100;
    end_animation = 15 //set end of animation in frames after inPoint
    //trim path depending on relative time
    linear(t, 0, end_animation/fps, start_val, end_val);
  • Mac Lad
    June 23, 2018 at 12:06 pm
    This Works Man !!! Thanks a ton
