Trim Paths to a filled circle
Hi Everyone,
If someone can share their AE wisdom that would be much appreciated.
I am trying to add a trim path to a shape layer (circle) and then animate the ‘Start’ option so the circle starts with 100% solid color fill then finishes with 0% (which reveals a video underneath),
The issue I cannot figure out is that I want the trim path to reduce the fill clockwise e.g. as if a big hand of the clock was removing the fill in a clockwise motion. At the moment, it looks like it is following the stroke path to remove the fill of the circle.
Is there a setting that I am missing or am I using the right method?
Cheers
Chris
