Activity › Forums › Adobe After Effects › Trim Paths not working as expected…
Posted by Joey Heaton on February 6, 2019 at 4:46 pmHi there,
For some reason, the Trim Paths are not working as expected. I’m using them with an Illustrator layer that was converted into a shape using “Create Shapes from Vector Layer.” You can see the problem below. Any idea what I’m doing wrong?
13091_screenrecording20190206at16.20.55.mov.zip
Thank you!
Max Haller replied 7 years, 7 months ago 5 Members · 6 Replies -
Kalleheikki Kannisto
February 6, 2019 at 5:48 pmWhat do you want it to do instead? That is how a trim paths with fill works. The path origin is in a bit of an odd location, other than that the behavior is as expected. You are filling a shape that remains when you remove a certain length of the path.
Senior Graphic Designer -
Joey Heaton
February 6, 2019 at 6:10 pm -
Joey Heaton
February 7, 2019 at 11:35 amHi,
Doing that just causes it to disappear. It looks like I’m going to have to mask it manually?
Thanks.
Michael Szalapski
February 7, 2019 at 9:51 pmNot necessarily. Turn the fill off, but turn the stroke on and make sure you have a white stroke. I’m guessing that the shape isn’t a simple stroke in Illustrator but two circles that are kinda filled, but it’s just a guess.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Max Haller
February 8, 2019 at 5:12 pmIts not doing what you’re expecting because the shape isn’t a stroke. Its probably a stroke in illustrator but its being treated as a solid shape. You can see that it’s trimming the path around the shape you thought was a stroke. See how it says Group 1 instead of shape, open that up and see if it’s multiple shapes that are merged or something.
It’s not making random shapes, the arcs that pop up is from the trim path drawing the objects in the group 1 and then your telling it to fill that group with white. If its a simple shape you’re better off just using the pen tool in after effects and setting the stroke width to however wide you want it. Remove the fill and use stroke color instead and then trim path should do what you’re imaging.
