Activity Forums Adobe After Effects Trim paths continuous loop (traveling down road animation)
  • Trim paths continuous loop (traveling down road animation)
    Posted by Chris Vo on August 21, 2015 at 8:14 pm
    Hi All,
    I want to do a simple traveling down a road toward a city animation :
    (rough sketch)
    I thought the easiest thing would be to dash a stroke on a shape layer, add a camera and orient the stroke for perspective, then do a trim paths to animate the lines coming toward the camera. However I’ve quickly realized that trim paths isn’t continuous — is there a way to loop it continuously? loopOut? Or is there another approach I should be using? Repeater? 3D stroke?
    Last resort is I’ll create a giant road graphic and move the camera, but I was hoping there was a more pragmatic solution.
    Chris Vo replied 10 years, 10 months ago 2 Members · 3 Replies
  • Chris Vo
    August 21, 2015 at 8:58 pm
    Temporary (actual) solution — I’m just going to make the path really really long.
  • Frank Feijen
    August 21, 2015 at 9:54 pm
    I’d try to make a seamless loop with the offset-effect…
  • Chris Vo
    October 11, 2015 at 6:18 pm
    Seamless loop with offset-effect was the ticket! Thanks, Frank.
