Activity Forums Adobe After Effects Expressions Trim path end with set value + wiggle?
  • Trim path end with set value + wiggle?
    Posted by Johannes Tönne on February 13, 2021 at 7:35 pm
    Hi there,
    i am trying to add a wiggle to the end value of a trim path, which is connected to the start value. So, basically what i want to do for the trim end is:
    – take the start value of the trim – add 10% – add ad wiggle
    adding the 10% is easy of course (i just pickwhipped the start value, then typed “+10”). But how do i add the wiggle on top?
    Thank you in advance.
    best regards
    johannes
    Johannes Tönne replied 5 years, 6 months ago 2 Members · 2 Replies
  • Filip Vandueren
    February 13, 2021 at 9:01 pm
    You could do this:
    w=wiggle(2,10) - value;
    trimStart + 10 + w; // pseudocode
    By subtracting the original “value” from wiggle() you get just the relative randomization which you can then add to any other calculation.
  • Johannes Tönne
    February 14, 2021 at 12:34 pm
    Thank you, -value did the trick.
