Activity Forums Adobe After Effects Expressions Trim path end to position of a null
  • Trim path end to position of a null
    Posted by Pontus Danielsson on January 16, 2020 at 1:34 pm
    Hi!
    I’m making a graph that get its data from a json file.
    This is the setup:
    I have a shape layer in a straight line that consists of 100 points.
    Each point is attached to a null object.
    Each null object’s Y position is driven by a json file:
    eval("var SoMe=" + footage("SoMe_total.json").sourceText);
    followers = SoMe[0].jan20;
    min = 0;
    max = 3000000;
    max_movement= -1300;
    newBaseline = 1836;
    y = ((followers-min)/max)*max_movement + newBaseline;
    [y]
    For each month, a new number is added to the json file and the graph therefore continues.
    As for now I have animated a trim path to the shape layer that is controlled by a slider.
    min = 0;
    max = comp("Main").layer("GRAPH CTRL").effect("FOLLOWERS GRAPH 2020-2028")("Slider");
    if(numKeys > 1){ ease(time,key(1).time,key(2).time,min,max); }else{ max; }
    Here is my question. Since there are 100 null objects (100 points on the shape layer) and the slider goes from 0-100, is there a way to map the slider value (the trim path end) to go to the next null layer?
    So if I type in 53 in the slider, the trim path end would go to the position of null 53…
    I hope i makes sense…
    best regards,
    Pontus
    Pontus Danielsson replied 6 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
