Activity Forums Adobe After Effects Trim Path Angle
  • Trim Path Angle
    Posted by Heru Prasetyo on April 22, 2015 at 9:20 am
    Is there a way to change the angle my trim path “grows” from? It seems as though the offset angle only allows me to change the direction around a circle? What I want is for this shape to “grow” from end to end, not around the circle it currently is.
    The only way I can think of fixing this problem is by creating the shapes again from a single path and add a stroke, then keyframe the trim paths?
    If i’ve explained this badly, i’ve provided some images to illustrate the problem further.
    Roland R. kahlenberg replied 11 years, 4 months ago 2 Members · 1 Reply
