TRIM ODDITY IN FCP 6
Hi Cow-ers:
Posted this before, but got no responses — so here goes again…
I’m cutting a feature shot on P2 (DVCPRO HD 720p24), both on my desktop Dual G5 and my PowerBook 1.67. I’m cutting with merged clips (double-system sound synched to picture) and most times (but not all) when I enter the trim window, the incoming/outgoing shots display correctly at first, but if I trim either of them, they both jump visually to something much later/earlier than the trim calls for.
For example: a 1 frame trim, and the trim number could jump 9:16 later…and the like. It almost seems as if it jumps to the end/beginning of the full clip, but I haven’t double-checked that…
When I preview the edit, it displays it correctly, trimming only the one frame.
What is going on? Is this a known FCP 6 bug, or something I’m not doing correctly? Does it relate to the merged clips somehow?
Any advice would be much appreciated. Needless to say, I’m using the trim function a lot.
Best, JIM.
OSX.4.10
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.5 TB RAID
AVID XPRESS PRO/MOJO
