  • Posted by Van Kowalski burdge on December 26, 2008 at 1:08 pm
    coming from a long road with avid…I’m finally coming over to the bright side. I apologize in advance for most of my questions.
    when in fc trim mode, I want to preview only one side of the edit to find an audio pop. I can do this but I must open up user prefs/editing and change it. Is there a keyboard shortcut that can change it to 0 on either side of the cut? Avid has fields on the trim mode window to change this quick and I was hoping there was a quicker way to do this on fc.
    tia,
    Van
    Van Kowalski burdge replied 17 years, 9 months ago 3 Members · 4 Replies
  • Richard Harrington
    December 26, 2008 at 4:09 pm
    Press U to cycle trim sides
    Use < and > to trim single frames
    Multi trim prefs can be set inside of FInal Cut Pro > Preferences windows
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Van Kowalski burdge
    December 26, 2008 at 5:52 pm
    I’m sorry, I did not make myself clear. I do know how to do the trims but I want to “preview” only one side of the preview. I’m having a difficult audio edit…so I want to preview the cut and be able to quickly change the each side to 0 to hear where the clicks are or to hear the sibilance.
    I know you can change it in the settings on fc but it’s 4clicks and a menu just to get to the entry field…so my question is there a keyboard shortcut to get there or better yet to set each side to 0.
    Here is where you can change it on an avid trim window and I belive there is a keyboard shortcut to jump right in to the left field box and then tab to the right box.
  • Captain Mench
    December 30, 2008 at 10:15 pm
    Hmmm… that would be really handy.
    Here’s an option though.
    Use Shift-\ to play between In/Outs. Set sequence in outs where needed. You can also use Control-L to turn on the LOOP and then trim as it loops.
    Only work around I could think that would get you close to what you want to do.
    Mike
    January 2, 2009 at 3:56 am
    close..thanks!
