Activity Forums Adobe Premiere Pro trim edit window keeps closing when I press spacebar to play
  • trim edit window keeps closing when I press spacebar to play
    Posted by Nick Natteau on September 7, 2013 at 11:11 pm
    Not sure if anyone else has run into this problem. But in Premiere Pro CC, whenever I open the trim window with “T”, as soon as I hit play, the trim window closes and I’m back to the Program Monitor window.
    I’m essentially unable to play anything in the Trim edit window because I soon as I do, the window closes.
    Has anyone else run into this problem in Premiere Pro CC and is there a solution???
    I googled and can’t find this issue discussed anywhere.
    It’s driving me crazy because I can’t perform any edits in the trim window.
    Nick Natteau replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
