Activity › Forums › Adobe After Effects Expressions › Trim comp by avoiding music track layers
Posted by Avinash Ramanath on May 2, 2017 at 7:21 amHi All, need your help.
I have the below function to stack layers in a comp and trims itself. Can you help in modifying this so that it ignores music tracks with .mp3 and .wav extensionkillDeadSpace(slateComp, false);var totalDuration = 0;
for(i = 0; i < slateComp.numLayers; i++) {
currLayer = slateComp.layers[i + 1];
totalDuration += currLayer.source.duration;
slateComp.duration = totalDuration;Avinash Ramanath replied 9 years, 3 months ago 2 Members · 6 Replies -
Steve Sierra
May 2, 2017 at 8:55 amHi,
I’m not sure this is the most efficiant way, but you could maybe use this. You have to be at the Item level :
var currItem = currLayer.source;
if(currItem.hasAudio == true && currItem.hasVideo == false){
}else{//———————-Your code here—————
I can’t test this, I have a project rendering… and I think “.hasAudio” doesn’t exist for CS6, and that’s what I’m using.
Hope it helps anyway,Cheers !
Steve Sierra
May 2, 2017 at 10:39 amDid you do it like this ?
var currLayer = slateComp.layers[i + 1];
}else{
slateComp.duration = totalDuration;Still can’t test 😉
Avinash Ramanath
May 2, 2017 at 2:39 pmThanks Steve,
It was getting complicated to recognise the source of the file hence iam referring to the layer by name as “music”. I will post the working code here in some time. Thanks -
Avinash Ramanath
May 4, 2017 at 4:57 amHi,
Here is the working code.function killDeadSpace(cItem, preserveOverlap) {
if(preserveOverlap == true) {for(i = cItem.layers.length; i > 1; i--) {
var curLayer = cItem.layers[i];
if(curLayer.name == 'Music') continue; // ignoring this layer
var prevLayer = cItem.layers[i - 1];
var deadSpace = (curLayer.inPoint) - (prevLayer.outPoint);if(deadSpace > 0) {
var inBefore = curLayer.inPoint;
var diff = curLayer.inPoint - curLayer.startTime;
curLayer.startTime = prevLayer.outPoint - diff;
var inAfter = curLayer.inPoint;
var amountMoved = inBefore - inAfter;var j = curLayer.index;
while(j < cItem.layers.length) {
//cItem.layers[j + 1].label = 12;
cItem.layers[j + 1].startTime = cItem.layers[j + 1].startTime - amountMoved;
j++;
else {continue;
else {
for(i = 2; i <= cItem.layers.length; i++) {var curLayer = cItem.layers[i];
curLayer.startTime = prevLayer.outPoint - diff - 0; // time to overlap
Avinash Ramanath
May 4, 2017 at 12:25 pmHi,
Can you please make the above code work, even if the layers stacking order is from bottom to top.
