Activity Forums Adobe After Effects Expressions Triggering random expression with another layer’s property
  • Triggering random expression with another layer’s property
    Posted by Ben Robinson on January 30, 2017 at 9:37 pm
    I posted a few days ago looking for a way to loop an opacity fade up / stay on / fade down, with fade / stay on times linked to sliders. I actually managed to make that one work myself, starting with another expression from, of all things, a built in preset. What I ended up with was this:
    ctrl = comp("MAIN COMP").layer("TIMING CONTROLS");
    fadeTime = framesToTime(ctrl.effect("Fade In/Out Time (Frames)")("Slider"));
    onTime = framesToTime(ctrl.effect("On Time (Frames)")("Slider"));
    fadeDur = fadeTime*2+onTime;
    t = time%fadeDur;
    fadeInOpacity = linear(t, inPoint, inPoint+fadeTime, 0, 100);
    fadeOutOpacity = linear(t, fadeTime+onTime, fadeDur, 100, 0);
    (fadeInOpacity * fadeOutOpacity) / 100
    It works just as I want it to. What I also need to do though–and I replied to my own post in the hopes of finding an answer, but might have overcomplicated things–is trigger two other “events” based on the opacity working on the above expression. I want freeze frames of a precomp to change to another random frame every time the opacity hits zero, so that when it fades back up it will show a different frame. Similarly, I’d like a colour control adjustment layer within the pre comp to cycle randomly though a set of six RGB values, so that each subsequent freeze frame is a different, random colour. I’ve come very close to making it all work, but just can’t quite see my way through it.
    Ben Robinson replied 9 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 30, 2017 at 10:10 pm
    I think the key is that opacity hits zero at the end of each fadeTime. So for random stuff to change at that time, you need to do something like:
    n = Math.floor(time/fadeDur);
    seedRandom(n,true);
    // do random stuff
    for sequencing, it would be like this:
    seqLen = 6;
    n = Math.floor(time/fadeDur)%seqLen;
    // use n as the sequence index
    Dan
  • Ben Robinson
    January 30, 2017 at 11:07 pm
    Thanks Dan. That works perfectly. So, it turns out, did another method I’d already arrived at–possibly even from one of your own, after much reading / experimenting…
    segDur = framesToTime(ctrl.effect("On Time (Frames)")("Slider"))+framesToTime(ctrl.effect("Fade In/Out Time (Frames)")("Slider")*2);
    minVal = inPoint;
    maxVal = framesToTime(37);
    seed = Math.floor(time/segDur);
    seedRandom(seed,true);
    random(minVal,maxVal);
    Even though it wasn’t directly linked to the opacity it was linked to the same duration-setting sliders. For some reason, though, it wasn’t working for a couple of days. Not sure if I’d mistyped / mis-linked something or what–but the opacity and frame change just didn’t marry up. I like your method with the direct link to the opacity though. Seems like it will give more consistency.
    Ben
