Triggering RAM Preview via script
Does After Effects allow a script to trigger the RAM preview? I was hoping to make one that would turn off the visibility of a certain type of layer (probably determined by label type), then trigger a RAM preview… and ideally revert the visibility change once the preview is stopped.
The visibility bit is not a problem, but I haven’t been able to find any documentation for how I would call the preview, and am guessing that means it might not be possible… or just way more complicated than it’s worth. Any thoughts?
