Activity › Forums › Adobe After Effects Expressions › Triggering Animation with SoundKeys
  • Triggering Animation with SoundKeys
    Posted by Anders Hattne on November 4, 2021 at 5:27 pm
    There’s probably info out there on this, but I’m too stressed to find it!!
    The idea is to trigger timeRemap when a certain threshold is passed.
    I figure I could use Dan Ebberts “Triggering Expression With Audio” or Beat Counter; Say that layer 5 plays once the Threshold has been passed the 5th time…
    Tried that but the layer gets animated every time the threshold is passed..
    I just want it to be played once and then animate on various layers..
    See if I can get my head around the beatcounter and mix the two ideas together!!
    But this.. is above my current skillset ..
    Thankful for any replies!!
    threshold = 20.0;
    audioLev = thisComp.layer(“soundKeys Average”).effect(“Sound Keys”)(“Output 1”);
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    while (true){
    t = frame * thisComp.frameDuration;
    if (above){
    if (audioLev.valueAtTime(t) < threshold){
    frame++;
    break;
    }else if (audioLev.valueAtTime(t) >= threshold){
    above = true;
    if (frame == 0){
    break;
    frame–
    if (! above){
    t = 0;
    }else{
    t = time – frame * thisComp.frameDuration;
    value + t
    Anders Hattne replied 4 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 4, 2021 at 7:09 pm
    Not fully tested, but maybe something like this:
    beat = 5; // which beat to trigger on
    threshold = 20.0;
    audioLev = thisComp.layer("soundKeys Average").effect("Sound Keys")("Output 1");
    above = false;
    fCur = timeToFrames(time);
    f = 0
    fSave = [];
    n = 0;
    while (f <= fCur){
    t = framesToTime(f);
    if (above){
    above = false;
    above = true;
    n++;
    fSave.push(f);
    f++;
    (n >= beat) ? time - framesToTime(fSave[beat-1]) : 0
  • Anders Hattne
    November 4, 2021 at 7:36 pm
    Works like a charm!!
    I was butchering together the two expressions like Frankenstein and got a “time out while waiting for engine” as a monstrous result.
    Your solution works perfectly. Thank you so much!!
