Activity Forums Adobe After Effects Expressions Triggering an expression function using a timeline marker
  • Triggering an expression function using a timeline marker
    Posted by Harold Durnez on November 10, 2020 at 3:24 pm
    ​Hi there
    I have the below ‘countdown timer’ expression working just fine.
    However now I would like to action this expression by use of a Layer Marker on my timeline.
    i.e. only when my timeline hits my marker at say 10 seconds, do I want this ‘countdown’ expression to start from the input time.
    rateOfSpeed = 1;
    clockStartTime = effect(“timer duration”)(“Slider”)*60;​ // This is a pickwhipped slider control
    function addZero(n){
    if(n<10) {return “0” + n}else{return n};
    clockTimeNumber = Math.floor(clockStartTime – rateOfSpeed*time);
    clockTimeNumber/60;
    minutes = Math.floor(clockTimeNumber/60);
    seconds = clockTimeNumber%60
    minutes + “:” + addZero(seconds);
    } else {
    value
    Harold Durnez replied 5 years, 10 months ago 2 Members · 2 Replies
  • Filip Vandueren
    November 10, 2020 at 3:58 pm
    Instead of this part clockTimeNumber = Math.floor(clockStartTime – rateOfSpeed*time);
    Try this:
    t = time - thisComp.marker.key(1).time;
    if (t<0) t=0;
    clockTimeNumber = Math.floor(clockStartTime - rateOfSpeed*t);
    Keep the rest of the expression the same, although there seems to be something missing in the part you pasted here (it endse with an else-clause, but there’s no if before it)
  • Harold Durnez
    November 10, 2020 at 5:07 pm
    That worked perfectly thanks Filip!
    to answer your question; the IF is hiding in the addZero function.
    To further this, what would need to be added to pause and unpause this timer using markers?
    Thanks man, Lifesaver!
