Activity Forums Adobe After Effects Expressions Triggering a layer from another composition
  • Triggering a layer from another composition
    Posted by António Ferreira on August 18, 2015 at 8:15 pm
    Hello everyone,
    I’m trying to trigger Jesus eyes… 🙂
    I’ve used the expression below in the “position” of both eyes layers and I’m controling them using a null object named “eyes_ctrl” in other composition.
    The fact is that I can control them, but when I add some keyframes in “postition” of the null object, the effect just vanishes, and I lose control of the eyes. Do I need to change or renew the expression?
    comp("jesus").layer("eyes_ctrl").transform.position;
    António Ferreira replied 10 years, 8 months ago 3 Members · 5 Replies
  • Dan Ebberts
    August 18, 2015 at 11:27 pm
    Is the layer with the expression in a precomp nested in your “jesus” and the precomp layer doesn’t start at the beginning of the outer comp? If so, this may fix it:
    C = comp(“jesus”);
    L = C.layer(thisComp.name);
    C.layer(“eyes_ctrl”).transform.position.valueAtTime(time+L.startTime)
    Dan
  • António Ferreira
    August 19, 2015 at 1:16 am
    Thank you!
    I guess that’s not the case!
    Well, i’ve got:
    Jesus > Olhos_Jesus > Olhos_Jesus_2
    The null object is inside “Jesus” comp, and the eyes are inside “Olhos_Jesus_2” comp
    “Olhos_Jesus_2” is inside “Olhos_Jesus” witch is inside “Jesus”.
    All of them start in the very first frame.
    🙂 any help is very welcome 🙂
  • Spencer Tweed
    August 23, 2015 at 8:07 pm
    Your original expression looks fine to me. Maybe try looking for something else…? There’s a lot that can go wrong when linking between comps – and a lot that can go wrong when referencing a position. Is anything parented? Any 3D layers? Try isolating what’s going wrong.
    – Spencer
  • António Ferreira
    August 27, 2015 at 7:36 pm
    Hello, now here’s what I’m trying to do (CC 2014 version)
    When I add keyframes to null’s “position” I lose control of the eyes :/
    https://www.sendspace.com/file/ucqmhr
  • António Ferreira
    August 28, 2015 at 9:15 pm
    Hello people.
    I’ve figured out what’s wrong.
    It seems that tracking with a null, the “position” of an object inside a certain comp, doesn’t work if that comp has “time remapping” activated, which was the case.
    I just deactivated “time remapping” an it works.
    My blinking option stoped working, but I’ve found another solution for that matter.
    Anyway, the main problem is solved 🙂
    Thank you all.
