Activity Forums Adobe After Effects Trigger “position” with markers
  • Trigger “position” with markers
    Posted by Henri Yates on October 25, 2021 at 10:31 am
    Hello, I want to animate “position” of an item. I want that the marker’s comment (which will be a number) to add or subtract from the previous keyframe value and place and new keyframe under the marker.
    For example; the first keyframe (marker, Y Position) is 50, which I initially set. I want the second keyframe value to be the second marker’s comment plus the previous keyframe’s second value (Y Position) which is 50 so the second keyframe will be 5 0+ 150 = 200. And the third keyframe will be 200 + 30 = 230 etc.
    Any help?
    Meng Zhiqun replied 4 years, 10 months ago 2 Members · 1 Reply
  • Meng Zhiqun
    October 30, 2021 at 7:34 am
    You can try this. Put this expression in the position. 🙂
    var aniTime = 10/30;// Change this to change the timing it takes to go up/down.
    n = 0;
    if (marker.numKeys > 0) {
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) {
    n--;
    if (n == 0) {
    var y = value[1];
    }else{
    var y = value[1] + linear(time, marker.key(n).time, marker.key(n).time+ aniTime, newY().split(",")[0] , newY().split(",")[1] );
    function newY(){
    var curYVal = 0;
    var newYVal = 0;
    var target = thisLayer;
    var tNumKeys = target.marker.numKeys;
    if (tNumKeys > 0) {
    for (var i=1;i<=tNumKeys;i++){
    var curKey = target.marker.key(i);
    if (curKey.time <= time) {
    newYVal+= Number(curKey.comment);
    try{
    curYVal+= Number(target.marker.key(i-1).comment);
    }catch(e){
    curYVal = 0;
    return curYVal + "," + newYVal;
    var x = value[0];
    [x,y];
    Hope this helps!
