Activity Forums Maxon Cinema 4D Trigger “Calculate” cache button with Xpresso and User Data.
  • Trigger “Calculate” cache button with Xpresso and User Data.
    Posted by Joseph Herman on September 1, 2021 at 6:19 pm
    Hello everybody,
    In the Jiggle Deformer, under Cache, there is a Calculate button.
    I want to invoke that button with Xpresso. I dragged the deformer into the Xpresso window to make a node for it. I’ve attached an image that shows the input ports to the node under Cache.
    My question is, how can I kick off the Caching of the Jiggle deformer? Which port (based on the attached image) should I use for the input. And what kind of User Data control can I use to set it off? Should I use a Boolean control?
    Thank you so much!
    Joe.
    Joseph Herman replied 5 years ago 1 Member · 0 Replies
  • 0 Replies
