Activity Forums Adobe After Effects Expressions Trigger animation on passing Nth marker in main timeline
  • Trigger animation on passing Nth marker in main timeline
    Posted by Allard Rothengatter on October 29, 2014 at 6:02 pm
    Hey guys,
    I have the following challenge.
    In order the make my animation more flexible I’d like to start an animation in a secondary comp when the main comp passes a specific comp marker. I’ve set a number in the “Chapter” field of the marker so I can check wheter it’s the right animation.
    This works pretty good, but as soon as a new marker is closer to the current time then the one that triggers the animation, it’s being reset the default values.
    What I’d like is to set a “global” variable that will not refresh on each frame as soon as the specific marker is in the past. So that my animation (in this case a linear opacity fade in) stays at 100% in stead of falling back to 0 as soon as time approaches the new marker.
    This way I hope to achieve that by moving a marker on the main timeline, all animations on nested comps will automatically start at the right time.
    I know this all sounds pretty vague, but I sinerely hope some one can help me out with this.
    Thanks!!
    Cheers,
    Allard
    m = comp('SmartBox Overlay').marker
    hasPassed = 0;
    if (m.numKeys > 0) {
    next_frame=m.nearestKey(time);
    if(next_frame.chapter == 1) {
    t = next_frame.time;
    hasPassed = 1;
    if (time > t) {
    ease(time,t,t+0.5,0,100);
    } else {
    0
    } else {
    if(hasPassed == 1) {
    100
    } else {
    0
    } else {
    0
    Allard Rothengatter replied 11 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 29, 2014 at 6:53 pm
    Unfortunately, you can’t do global variables. I’d try it this way:
    m = comp('SmartBox Overlay').marker;
    t = 0;
    for (i = 1; i <= m.numKeys; i++){
    if (m.key(i).chapter == 1){
    t = time - m.key(i).time;
    }else if (m.key(i).time > time){
    break;
    ease(t,0,.5,0,100)
    Dan
  • Allard Rothengatter
    October 29, 2014 at 6:59 pm
    Dan,
    This is exactly what I was looking for.
    Thanks a million for the lightning fast response to my vaguely worded question 😉
    I’ve made some minor adjustments to trigger the animation 2 secs. before the marker.
    But it works like a charm now. No need for me to adjust keyframes in multiple comps anymore.
    Thanks again!!
    Cheers,
    Allard
