Activity › Forums › Adobe After Effects Expressions › Trigger Animation on Audio Threshold
  • Trigger Animation on Audio Threshold
    Posted by Dan Zucco on July 30, 2013 at 8:54 am
    Hello All,
    I have an audio track with separate layers for separate instruments. I have made a series of animations which I would like triggered dependant apon the threshold of the Audio, ie. when audio hits 100 go to frame 0 of Graphic comp.
    Not great at expressions and have tried adapting other similar expressions to no avail.
    If anyone can direct me to a tutorial, or forum post or knows the best solution for this that would be great. I can use SoundKeys as well if that helps and would like to try to avoid using markers as triggers as the track is long and I have to do it for every instrument with a short turn around time.
    Hope you can help.
    I look forward to hearing from you.
    Best,
    Dan
    Dan Zucco replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
