Activity Forums Adobe After Effects Expressions Trigger a keyframe animation with a conditional
  • Trigger a keyframe animation with a conditional
    Posted by Riccardo Sinti on December 2, 2015 at 10:13 pm
    I have a stroked path animating on with trim paths keyframed on the “End” parameter from 0% – 100%.
    I have other paths that branch off the main path which animate on in the same way.
    So branch one starts when main path hits 25%.
    I’m looking for an expression on branch 1’s “End” parameter, which is keyframed between 0% – 100%,
    that will say if “end” main path = 25% start the keyframed animation.
    this way I can adjust the timing of the main path without having to slide branch 1’s keyframes to adjust and I can do this for other branches as well.
    Thanks in advance!
    Riccardo Sinti replied 10 years, 9 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    December 3, 2015 at 12:31 pm
    How about linear(Pick End parameter here, 25, 100, 0, 100)
  • Riccardo Sinti
    December 3, 2015 at 4:22 pm
    Needs more than that but thanks!
    After some searching I started playing around with this this but it doesn’t work
    start = thisComp.layer(“MAIN_PATH”).content(“Group1”).content(“Trim Paths 1”).end;
    t1 = key(1).time;
    t2 = key(2).time;
    if (start = 27) t = linear(time,t1,t2) else t = 0;
    valueAtTime(t)
    there are some elements here that I’m sure are necessary like the variables but not sure where to take it.
