Activity Forums Adobe After Effects Tricky Stabilization: actress with no background <-
  • Tricky Stabilization: actress with no background <-
    Posted by Michele Poggi on November 9, 2011 at 12:29 pm
    Hey guys. 😉
    Here we are, I have this tricky clip to stabilize.
    The actress is -of course- alive so it’s not easy to me to figure out what to do.
    My best shot was to track her eyes, but it didn’t turn out well.
    I’ve uploaded the video for a better understanding, do you have any tip or idea?
    As always, thanks. Let’s see if we can find a solution for this one.
    https://reels.creativecow.net/film/tricky-stabilization
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Rousselos Aravantinos replied 14 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • Rousselos Aravantinos
    November 9, 2011 at 1:47 pm
    i might need a tutorial on how to post video /or still on cow.
    Is this a video or a photo still?
    Your description makes me think that you may have to try the stabilize engine inside mocha
    Use eyebrows instead eyes but keep untouched the first and ending frame
    So you will have a smooth camera motion path.
    But again if i can watch ur video i might be wrong.
    Btw..i assume your door/shadows fx shot is completed right?
  • Roland R. kahlenberg
    November 9, 2011 at 2:31 pm
    This one is tricky cos you’ve got camera movement as well as movement from the subject. Also, there seems to be less movement from her eyes, hairline and nose – so perhaps those are good places to track.
    If you have AE CS5.5, it will be interesting to see how the Warp Stabilizer handles this shot.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
    November 9, 2011 at 2:46 pm
    ok…i blame safari for windows!!!
    your video appeared as still with no playback controls. On firefox works ok.
    So..
    i thing you should try mochas planar tracker
    from 0 -12 sec try to track the shoulder behind book.
    Then you can add a new spline on her dress chest to the 20 sec.
    then candle and table can offer a final texture for a good tracking.
    Use keyframes to smooth cameras path.
    Looks easy..
  • Michele Poggi
    November 10, 2011 at 11:36 am
    It indeed can be easy, it’s that I’m still practicing Mocha, so using multiple splines is still something I have to test out. Same goes for the Warp Stabilizer. Thanks for the tips, I’ll make sure to upload the result.
    Editor Video
    Graphic Designer
    Digital Compositor
    November 10, 2011 at 12:01 pm
    hey
    as Roland R. Kahlenberg already recommended try to fix it
    using AE CS5.5 (warp stabilizer) I don’t know if own this latest version.
    I’m still on CS4 …so if you are still practicing using mocha,
    as an alternative those auto steady plugins such red giant stabilizer, or 2d3 steadymove.
    It might be one click case…
    Boris have a similar plugin but it’s not my favorite!
    Virtual dub does this steady miracle too..and it’s free…but i assume you
    dont wanna drop yourself into Virtual dub with deshaker plugin.
    November 10, 2011 at 12:07 pm
    FAST TYPING SIDE fx…
    so let me add missing words ( bold )
    hey
    using AE CS5.5 (warp stabilizer) I don’t know if you already own this latest version.
    I’m still on CS4 …so if you are still practicing using mocha, you may wanna try
  • Michele Poggi
    November 19, 2011 at 3:09 pm
    In the end I found a way to avoid VirtualDub. I did indeed use it for all these years but most for converting and filtering with Avisynth.
    Editor Video
    Graphic Designer
    Digital Compositor
    November 19, 2011 at 3:50 pm
    so what was the “healing” tool for you ?
