Activity Forums Adobe After Effects Tricky Interpolation
  • Tricky Interpolation
    Posted by Yussef Cole on October 31, 2005 at 7:49 pm
    I am using an illustrator world map file and instead of using a 3d camera i am animating the layer’s scale and anchor point to simulate camera moves around the map. All of this was working splendidly but recently instead of moving from point a on the map to point b in a linear fashion (when animating scale and anchor) AE interpolates the movement into a weird arc. basically it creates a bezier path when there was none. granted i’m using easy ease keyframes but i still don’t understand the relationship between interpolated time and motion. linear keyframes also allow the bezier interpolation to occur. hope this made even a little sense,
    yussef
    John Dickinson replied 20 years, 10 months ago 2 Members · 1 Reply
  • John Dickinson
    October 31, 2005 at 8:15 pm
    Try selecting the problem keyframes and changing the spatial interpolation to linear either by Command clicking (PC: Control) on the keyframes or selecting the keyframes and choosing KEYFRAME INTERPOLATION from the ANIMATION MENU.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
